shynn
- Tải file đính kèm về up lên host
- Vào ACP-> ACP > Users > Custom User Fields > Create New Field
Điền theo mẫu sau:
Basic Information:
Field ID: SoundChat
Title: Âm báo khi có tin nhắm
Description: Tắt / Bật âm báo
Display Location: Tùy Chọn
Options for Choice Fields:
Field Type: Radio Buttons
Possible Choices: Value: yes - Ký tự: Có
Value: no - Ký tự: Không
General Options:
[x] Field is required
[x] Show during registration
[x] User editable
Lưu lại - Vào ACP > Appearance > Template > dark_taigachat_chatbox
Tìm
Mã:<xen:require js="js/dark/taigachat.js?{xen:raw $taigachat.js_modification}" />
Mã:<xen:if is="{$visitor.customFields.SoundChat} == 'yes'"> <xen:require js="js/dark/taigachatSound.js?{xen:raw $taigachat.js_modification}" /> <xen:else /> <xen:require js="js/dark/taigachat.js?{xen:raw $taigachat.js_modification}" /> </xen:if>
- Vào ACP > Appearance > Template > dark_taigachat_popup
Tìm
Mã:<script type="text/javascript" src="js/dark/taigachat.js?{xen:raw $taigachat.js_modification}"></script>
Mã:<xen:if is="{$visitor.customFields.SoundChat} == 'yes'">[/INDENT] <script type="text/javascript" src="js/dark/taigachatSound.js?{xen:raw $taigachat.js_modification}"></script> <xen:else /> <script type="text/javascript" src="js/dark/taigachat.js?{xen:raw $taigachat.js_modification}"></script> </xen:if>
- Giờ user có thể vào Tùy chọn và tắt bật âm chatbox
