CNTT01
Snow Flower ✔
Link / Business Directory (Directory) 1.1.7.4
[VNXF.VN] XenKingDir- Link Business Directory (Directory) 1.1.7.4
Demo: http://www.kienthuc.name.vn/directory/
This directory works via a specified Forum (existing or new)
You can choose to hide this forum if you wish (so that the directory is just selectable from the Nav Bar)
You can also choose this forum to be moderated (so that directory listings are moderated)
- Allows users to add a location => Google Map
- Allows Users to add their own site links (1 Main and 3 deep)
- Works via a specified Forum, so admins can moderate submissions (untested)
- Can completely redefine the Directory Nodes using the ACP
- Comes with a default Business Directory Node set up
- Users can set listings to "claimable"
- Users can respond to the Directory Listing and give reviews (/reply to thread)
- Support multiple categories per listing (up to 5)
- The directory can go up to 5 categories deep
USA >> Texas >> Oklahoma >> Cities >> Pubs and Bars
Installation:
http:// www. yourforum.com/library/XenKingDir
1. Unzip the following zip file, and copy over the original files with the new versions (just copy over the entire XenKingDir Folder)
2. From within the Admin Control Panel: yourforum/admin.php?add-ons/
find the XenKingDir, and select the options Control >> Upgrade
3. Upgrade from file on server: library/XenKingDir/addon-XenKingDir.xml
Installation:
- Unzip the following zip file
- Upload this folder into the library folder of your XenForo root
- Go to ACP -> Add-ons -> Install Add-on -> Install from file on server
- Install from file on server: " library/XenKingDir/addon-XenKingDir.xml"
- Set the Directory forum in the administration control panel ACP>>Home>>Options>>[SurreyForum] XenKingDir
- Update default Directory nodes ACP>>Applications>>Link Directory
