Admin - Founder
xenforo 1.5.12 việt nam, | xenforo null | download xenforo 1.5.12
Today, we are pleased to release XenForo 1.5.12. This release fixes a number of bugs and issues that were found since the previous release. As this is a maintenance release, the vast majority of the focus was an increase in stability.
However, by default, we have replaced the Flash-based attachment uploader with an HTML5-based approach. This has increased compatibility with mobile devices and removes Flash as a dependency for multiple file uploads. The Flash-based uploader is now deprecated. While the HTML5 uploader is enabled by default, you can change back to the previous uploader code by disabling the "Use new HTML5 uploader" option. Generally this should not be necessary; however it's possible the new uploader may not be immediately compatible with all add-ons. If you run into problems uploading files in an add-on, you may wish to disable this option. Note that we have released updates to XenForo Media Gallery and Resource Manager that improve compatibility with the HTML5 uploader.
Some of the changes in this release include:
  • Add a CAPTCHA to account confirmation email resending if you've previously requested a resend recently to limit potential abuse.
  • Limit the number of times you can change your email within a short period of time to limit potential abuse.
  • Insert user change log records when two-step verification is enabled/disabled.
  • Log profile post and profile post comment edits to the moderator log for consistency.
  • Improved PHP 7.1 support with memory limit checks and numeric input handling.
  • Allow autolinking to include links containing "[" characters.
  • Allow the bounce parser to identify several other bounce message patterns.
  • Maintain ICC profiles when using the Imagick image processor only if supported by Imagick.
  • Move the Facebook logo sprite to be served locally as the existing URL no longer functions. (Note: this requires a new image within your image path: xenforo/connect_sprite.png.)
  • Add some padding around the message content element to prevent characters from being cut off in certain specific cases.
  • Fix sizing of the attachment thumbnail placeholder for non-image attachments when using a large thumbnail size.
  • In messages, only output the "person" metadata for registered members.
  • If the internal data path is a non-local path, ensure we use a local path for temporary files.
  • Adjust several phrases to use the more general wording of "the site" rather than "the board".
See the Resolved Bug Reports forum for further information.
The following templates have had changes:
  • account_confirm_resend
  • attached_files.css
  • attachment_editor
  • attachment_upload_button
  • attachment_upload_overlay
  • facebook.css
  • message_user_info
Where necessary, the merge system within the "Outdated Templates" page should be used to integrate these changes.
Please note that we are now formally recommending that you upgrade to PHP 5.4 or newer. Our intention with XenForo 2.0 is to require PHP 5.4 or newer. If you are running PHP 5.3 or 5.2, you will receive a warning when installing or upgrading XenForo.
( đang update hình ảnh nhé. các ae làm chuột bạch thử nhé. hiii)
  • XenForo 1.5.12 Released Full.rar
    5.3 MB · Lượt xem: 908
  • XenForo 1.5.12 Released Upgrade.rar
    5.4 MB · Lượt xem: 287
HVM
Thượng Đế
Em tưởng là có 2.0 rồi chứ :(
Admin - Founder
chắc chưa ổn. hiii
teamobi
Thượng Đế
Từ vbb convert sang xf nên xài full hay upgrade vậy ad?
Admin - Founder
chắc có lẽ vậy. hiii
hacobi1102
Thượng Đế
Từ 1.4.6 thì dùng full hay upgrade vậy bạn ơi?
Trên trang hướng dẫn của xenforo ghi:
Upgrades follow a very similar procedure to new installations, you simply need to upload the files and then follow the on-screen instructions.
Vậy là upgrade luôn được nhỉ :)
2-tek
Thượng Đế
Upgrade bình thường ,à, nó tự skip qua các version và nó sẽ install ver hiện tại!
tuna
Thượng Đế
mình mới xài, cài luôn bản này được ko ạ hay phải xài bản khác ổn định hơn
tuna
Thượng Đế
mình mới cài bản này, cài bd framework 2.5.9 không được, cả bản 1.5.8 cũng cài ko đc, chỉ có cài lên bản 1.5.11 thì được @@
2-tek
Thượng Đế
Xem lại đi, chứ mọi thứ hoạt động bình thường, không có cái nào lỗi cả! Demo cái blogs mình đấy! 1.5.12
tuna
Thượng Đế
tối qua mình cài cũng ko có lỗi, sáng nay mới nâng cấp host lên php 7 thì bị lỗi, mình nghĩ là do vậy, h đang xóa database và làm lại :v nhân tiện cho mình hỏi muốn vô hiệu hóa attchment có được ko nhỉ, host mình có 500mb nên ko muốn xài, sợ user up quá nặng :v
2-tek
Thượng Đế
Hahah các add-ons nó có tương thích php7 đâu, mỗi source xenforo là hổ trợ php7 thôi! =]]z
Vô hiệu hóa attackment thì vào Permission sét quyền lại, hoac option chình attack size = 0
tuna
Thượng Đế
Thank bác nhé :D
secpol
Thượng Đế
Bạn ơi cho mình xin mấy cái tem của trang chủ được không? Trang của mình có nhiều video nhưng chưa biết xử lý thế nào để cho ra ngoài trang home được.Thanks bạn !
2-tek
Thượng Đế
Bác cho e xin giao diện bác đc k
Templates của 2 bạn đây nhé: http://vnxf.vn/styles-xenforo-magazine-released-1-1.t9526.html, các bạn muốn chi tiết hơn thì pm @bcat95 nhé, ku em nó sẽ support!
Hỗ trợ trực tuyến
Support Quảng cáo
Mr. San (PVS)
Skype chat, instant message
Mr. Tuấn (Blue)
Mr. Trọng
0906 081 284
kinhdoanh@vnxf.vn
Điện Lạnh Thịnh Phát
