XenForo 1.5.0 Released **** By VNXF.VN
XenForo 1.5.0 Released **** By VNXF.VN - Những thông tin mới nhất về phiên bản Xenforo 1.5
Bản **** xenforo 1.5 sẽ được cập nhật sớm nhất tại topic này.
thông tin bên lề.
XF 1.5 Two-Step Verification and Security Improvements
Account security has become a hot topic recently. There are seemingly endless stories about password databases from popular sites being leaked. Because password reuse is common, we've started to see brute force login attempts using these leaked passwords. Maintaining account security has become a big priority. To help this, we've added a few new features.
Two-step verification, also known as two-factor authentication, requires you to provide two pieces of information to login. The general form is expressed as "something you know and something you have". "Something you know" is your password. "Something you have" is the new part. You may have seen this with other services, such as Google accounts. If you're familiar with that, you'll understand how it works in XenForo.
Two-step verification is something a user has to opt into sometime after they have registered. Enabling it increases security at the expense of a more complex login procedure. For many users--particularly ones that just lurk or only have a few posts--the "value" of their account is low so the cost may outweigh the benefit. However, for privileged users, the extra security should be worthwhile.
When you've enabled two-step verification, you will login with your username or email and password as normal. Once those are verified, we will determine if two step verification is needed. If so, you'll need to take the appropriate steps to complete that. Upon receiving that verification, you'll be logged in as normal.
Let's look at how each step works in more detail...
Two-Step Verification: Setup
two-step-setup1-png.108815
two-step-setup2-png.108816
To enable, you enter the two-step verification page from the account section. Note that you'll need to confirm your password before you can do any manipulation to the two-step verification settings.
To enable, you simply pick the method of verification you want to use. XenForo ships with two "primary" verification methods:
mới đó mà đã có rồi sao :))
Mình canh sẳn nó ra thì múc liền. :D
shynn
Oánh dấu liền :v
tpoclub
http://vnxf.vn/threads/xenforo-1-4-8-released-****-by-vnxf-vn.2621.html
- Trong thời gian chờ đợi, ae lên 1.4.8 trước thôi nào!!! jhgjdl;gdfgl;d
kiểu này chắc còn chờ 1.4.9 nữa.
sao mà họ đã nói tới 1.5.0 rồi ta? làm mình hóng lòi... hiii
thanhthai
khổ, như đẻ trứng ý, mình giờ mới up lên 1.4.8
uhm. thấy thông báo bên xenforo.com.
tưởng nó lên cái vèo luôn chứ?
vậy mà ra bản 1.4.8:D:D:D
dothanhtrung
chờ cho xong 1.5.0 rồi lên luôn thể, lên lắt nhắt mệt quá. giờ thấy tốc độ ra chả khác gì thời VBB bản 3.8.x
shynn
Bản này đã dùng đc chưa nhỉ ?
http://scriptznull.com/resources/xe...ed-unsupported-******-by-scriptznull-com.636/
namchelsea
anh em chưa nên cài vội chờ bản final ùi cài hihi
