Released XenForo 2.0.4 Released
XenForo 2.0.4 is now available for all licensed customers to download. We recommend that all customers running previous versions of XenForo 2.0 upgrade to this release to benefit from increased stability.
Download XenForo 2.0.4
Some of the changes in 2.0.4 include:
  • Prevent errors when CLI jobs run and return a phrase as a status message.
  • Prevent infinite loops when CLI jobs run and resume with a continue date in the future.
  • Fix error on contact form when validating.
  • Cached add-on entries could be used to build the active add-on cache with outdated information.
  • When merging templates, ensure that the version details are updated accordingly, even if the template itself hasn't been changed.
  • Remove unused duplicate method in the upgrader.
  • No longer force avatar dimensions to be no more than two times the opposite dimension.
  • Do not attempt to display content moderators if the associated content handler is unavailable (such as when it belongs to a disabled add-on.)
  • Add new phrase "month" for consistency with other time/date units which have singular and plural phrases.
As always, new releases of XenForo are free to download for all customers with active licenses, who may now grab the new version from the customer area.
Note: add-ons, customizations and styles made for XenForo 1.x are not compatible with XenForo 2.x. If your site relies upon these for essential functionality, ensure that a XenForo 2 version exists before you start to upgrade. We strongly recommend you make a backup before attempting an upgrade.
Current Requirements
Please note that XenForo 2.0.x has higher system requirements than XenForo 1.x.
The forthcoming XenForo 2.1.x release will have higher system requirements again (PHP 5.6).
  • PHP 5.4 or newer (PHP 7.2 recommended)
  • All of the official add-ons require XenForo 2.0.
Installation and Upgrade Instructions for XenForo 2.0
Full details of how to install and upgrade XenForo can be found in the XenForo 2 Manual.
Note that when upgrading from XenForo 1.x, all add-ons will be disabled and style customizations will not be maintained. New versions of add-ons will need to be installed and customizations will need to be redone. We strongly recommended that you make a backup before attempting an upgrade. Once upgraded, you will not be able to downgrade without restoring from a backup.
4share.vn
XenForo 2.0.4 Released Full
XenForo 2.0.4 Released Upgrade
pass giải nén: vnxf.vn
Fshare.vn
pass giải nén: vnxf.vn​
Anhan
Em Cmod Public_html thành 777
Và các thư mục sau thành 777
Mà vào upgrade theo link
http://salehue.com/install vẫn tạch ạ
Em tải file upgrade 2.0.4 về giải nén và up các file trong upload lên root của host ạ
Mong ace giúp đỡ :(
hosting ở đâu?
xem thử có hỗ trợ xenforo ko?
Anhan
Đợi hướng dẫn mãi hem thấy
Mò mãi cũng up lên đc
    152.1 KB · Lượt xem: 50
CTechCore
pass giải nén là gì thế Anh THB, em rõ vnxf.vn không được
nhoangnam
Web mình tự nhiên bị lỗi vào comment hay post bài đều báo lỗi này. Anh em biết giúp với...
http://forum.fixme.vn/forums/huong-dn.7/page-2
HTML:
Failed to load resource: the server responded with a status of 403 (Forbidden)
1.jpg Failed to load resource: the server responded with a status of 403 (Forbidden)
(index):1 The SSL certificate used to load resources from https://api.webtest.net will be distrusted in M70. Once distrusted, users will be prevented from loading these resources. See https://g.co/chrome/symantecpkicerts for more information.
/threads/lam-sao-d-gi-hang-cho-fixme.8/add-reply Failed to load resource: the server responded with a status of 500 (Internal Server Error)
core-compiled.js:42 PHP: <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>500 Internal Server Error</title>
</head><body>
<h1>Internal Server Error</h1>
<p>The server encountered an internal error or
misconfiguration and was unable to complete
your request.</p>
<p>Please contact the server administrator at
 [email protected] to inform them of the time this error occurred,
 and the actions you performed just before this error.</p>
<p>More information about this error may be available
in the server error log.</p>
</body></html>
defaultAjaxError @ core-compiled.js:42
tuna
sao bác nào cũng báo lỗi vậy, sợ quá chưa dám lên
zellkon
ai có theme cho bản này chưa mình xin với , import style các bản khác đều không được :(((
caolaogia7
style của nó giờ có tương đối rồi mà. Mình đang dùng xen 2.0.4 và styles ngoài cài vào nè
