XenForo 2.1.11 Released | XenForo 2.1.11 Released **** | Add-ons Released
Today, we are releasing XenForo 2.1.11 to address a potential security vulnerability. We recommend that all customers running XenForo 2.1 upgrade to 2.1.11 or use the attached patch file as soon as possible. (For customers running XenForo 2.0, we can only recommend upgrading to the latest version.)
The issue is a cross site request forgery (CSRF) on the login form. This may allow an attacker to unexpectedly log users into an attacker-controlled account. In some scenarios, this may cause privacy concerns if users take certain actions while logged into the incorrect account. Note that this does not give an attacker any access to the user's true account.
Applying a patch manually
Download the patch in the 2111patch.zip file attached to this message. It will contain the following files:
Note: If you decide to patch the files instead of doing a full upgrade, your "File health check" will report these three files as having "Unexpected contents". Because these files no longer contain the same contents your version of XF was shipped with, this is expected and can be safely ignored.
Current Requirements
Please note that XenForo 2.1.x has higher system requirements than XenForo 1.x.
- src/XF/Admin/Controller/Login.php
- src/XF/Pub/Controller/Login.php
- PHP 5.6 or newer (PHP 7.4 recommended)
- All of the official add-ons require XenForo 2.1.
