Released 2x XenForo 2.1.7 Released | XenForo 2.1.7 Released **** | Add-ons Released
XenForo 2.1.7 is now available for all licensed customers to download. We recommend that all customers running previous versions of XenForo 2.1 upgrade to this release to benefit from increased stability.
Most importantly, this release fixes a security vulnerability in XenForo. Only XenForo 2.1.0 and above are affected.
The issue is a XSS vulnerability. XSS (Cross Site Scripting) issues allow scripts and malicious HTML to be injected into the page, potentially allowing data theft or unauthenticated access.
The vulnerability affects content displayed in the "Approval queue" and requires specially crafted text to be entered into a relevant field for the content type (such as a thread title).
XenForo extends thanks to @rdn for reporting the issue.
We also give an honourable mention to @TickTackk who reported a "self XSS" issue to us related to the Froala rich-text editor that we use. While we do not consider this to be a security issue, we have fixed it and appreciate the time taken to report it.
While we recommend doing a full upgrade to resolve this issue, you can also patch the issue yourself with a simple template edit.
The template in question is approval_queue_macros.
To patch your existing installation, please follow these steps:
  1. Download the patched template which is in a file named 217patch.txt (attached to the bottom of this post).
  2. Log in to your Admin control panel, expand the Appearance navigation and click the "Templates" link.
  3. In the "Filter" field at the top of the list, type approval_queue_macros and open the template.
  4. Open the 217patch.txt file and copy the entire contents of this and paste it into the approval_queue_macros template, overwriting the existing content.
  5. Click "Save and exit".
  6. Repeat the steps above for all of your installed styles.
Note that if you upgrade to 2.1.7 or a newer version, you may undo/revert these template edits.
For instructions on how to resolve the issue by upgrading, and to see what else has changed in XenForo 2.1.7, please read on.
Download XenForo 2.1.7
or
Upgrade directly from within your control panel
Some of the changes in XF 2.1.7 include:
  • Ensure that some jobs do not attempt to complete or otherwise change state inside a transaction.
  • Ensure correct URL is used in the bookmark label filter when friendly URLs are not enabled.
  • Display correct username styling when viewing users linked to an IP.
  • In alerts and the news feed, ensure the "your post" link in the reaction item is clickable.
  • Ensure Gravatar rebuild job respects the options sent to it.
  • Prevent users from deleting their own accounts
  • Check for guest posts in post reaction items
  • Ensure login button when viewing a forum as a guest wraps properly.
  • Only try to hide the global action indicator if it's actually present.
  • Do not redirect back to the login page after a connected account request
  • Properly check for tag container inside tagger
  • Do not escape outbound email test subject phrase
  • Correctly handle add-ons created with incorrect casing when the namespace already exists.
  • Add additional wording to make it clear that the rejection reason will be shown to users awaiting approval.
  • Remove hard-coded height from payment inputs
  • Add missing phrase for 'could_not_find_subscriber_id_for_this_purchase_request'
  • Display PHP's memory_limit within server environment report.
  • Force choice builder to use temporary variable with set tags
  • Remove Google+ URL from the Google connected account template.
  • Allow disabling pointer events for nested tooltips
  • Remove unused parameter when fetching reaction phrase
  • Update promotion history interface for clarity
  • Fix post copier attachment regex
  • alert_post_reaction
  • approval_item_user
  • connected_account_associated_google
  • core_button.less
  • core_tooltip.less
  • forum_view
  • payment_initiate.less
  • reaction_item_post
  • thread_edit
As always, new releases of XenForo are free to download for all customers with active licenses, who may now grab the new version from the customer area.
Note: add-ons, customizations and styles made for XenForo 1.x are not compatible with XenForo 2.x. If your site relies upon these for essential functionality, ensure that a XenForo 2 version exists before you start to upgrade. We strongly recommend you make a backup before attempting an upgrade.
Current Requirements
Please note that XenForo 2.1.x has higher system requirements than XenForo 1.x.
  • PHP 5.6 or newer (PHP 7.3 recommended)
  • All of the official add-ons require XenForo 2.1.
  • xenforo_2.1.7_full_NULL_VNXF.zip
    12.5 MB · Lượt xem: 310
  • xenforo_2.1.7_upgrade_NULL_VNXF.zip
    12.5 MB · Lượt xem: 103
dinhkhang1
ai đã chuột bạch chưa :D
chơi mà sợ :v
tenland
E đang test thử đây, chắc là ổn
