Released 2x XenForo 2.1.8 Patch 2 Released | XenForo 2.1.8 Patch 2 Released **** | Add-ons Released
XenForo 2.1.8 is now available for all licensed customers to download. We recommend that all customers running previous versions of XenForo 2.1 upgrade to this release to benefit from increased stability.
Some of the changes in XF 2.1.8 include:
  • Attempt to merge reactions when merging posts
  • Only hydrate autoIncrement relation fields if there is no value in the parent entity. If the field has a value in the parent, an exception is now thrown.
  • Use \ZipArchive::=oVERWRITE flag when creating add-on zip to maintain compatibility with newer libzip versions
  • Ensure more consistent sorting is used for class extensions, code event listeners and template modifications.
  • Fix method checking when looking for API methods with versions appended.
  • Use optimal batch sizing when rebuilding templates and phrases.
  • Don't allow moderators to delete / edit warnings they have given if they have no permission to.
  • Update GitHub OAuth implementation to use header authorisation.
  • Handle rebuilding the active warning points in the User rebuild job.
  • Supress warnings when closing file pointer after copying file
  • Ensure a boolean value is returned when checking viewing permissions for conversations.
  • When importing deletion log entries, ensure the username and reason do not exceed the allowed max lengths.
  • Update register navigation item to ensure registration is enabled
  • Add widget data attributes to expanded new thread widget
  • Only fetch member stat results once on the overview page
  • Allow connected account providers to provide additional auth params
  • Only enqueue a reaction score rebuild when a reaction's score has changed, and simply rebuild scores for all reactions
  • Correctly identify Android version in the attachment manager
  • Upgrade jQuery to 3.4.1.
  • Validate parent IDs correctly when inserting tree structured data.
  • Prevent spam cleaner error when deleting a thread started by a spammer which has a redirect thread pointing to it.
  • Add a content template for user reports to improve extensibility.
  • Prioritize quick reply editor when multi-quoted quotes are inserted.
  • Add a minimum width to user change log cells
  • Add account email check to various places before sending mail
  • Offset the select-to-quote tooltip whenever touchevents are supported.
  • When rendering an unfurl do not double escape the proxied version of the URL.
  • Force max length constraint when handling a user ban reason.
  • Re-implement shortening of display text for very long URLs.
  • Log moderator attachment deletions to the moderator log.
  • Display error when trying to add template modification when not in development mode.
  • Workaround an issue with multiple color pickers which could prevent some color pickers from behaving as expected.
  • When previewing, ensure that sticky form submit rows stay stuck to the right place.
  • When importing paid subscriptions from vBulletin ensure user group changes are correctly logged.
  • Add a separate 'following' phrase for members others follow
  • Check preg_last_error() when processing template modifications
  • Improve news feed handler attachment handling
  • Prevent an error related to cache clearing of entity relations with an empty condition.
  • Reverse some changes related to template editing syntax highlighting which may actually break syntax highlighting entirely in some cases.
  • Echo a list of allowed extensions back in the error message given when a file that does not have an allowed extension is uploaded.
  • Include file and line number in exception XML response
  • Throw an error exception when a ban fails to apply
  • Handle failed bans in the warning point change service
  • Ensure that emoji conversions are done as expected for all characters.
  • Prevent a URL parsing error when following an HTTP request redirect to a path that starts with a "/" and contains a ":".
  • Improve styling of responsive data lists, particularly with checkboxes that have headings
  • Allow attachment data manipulation before copying files
  • Implement search source method to determine if a query is empty
  • Do URL canonicalization on the contact page and ensure that we link to misc/contact consistently (no trailing slash).
  • core.less
  • core_button.less
  • core_collapse.less
  • core_datalist.less
  • core_fa.less
  • core_input.less
  • core_list.less
  • core_utilities.less
  • font_awesome_setup
  • member_about
  • post_edit
  • report_content_user
  • setup.less
  • setup_fa.less
  • thread_edit
  • thread_move
  • widget_new_threads
As always, new releases of XenForo are free to download for all customers with active licenses, who may now grab the new version from the customer area.
Note: add-ons, customizations and styles made for XenForo 1.x are not compatible with XenForo 2.x. If your site relies upon these for essential functionality, ensure that a XenForo 2 version exists before you start to upgrade. We strongly recommend you make a backup before attempting an upgrade.
Current Requirements
Please note that XenForo 2.1.x has higher system requirements than XenForo 1.x.
  • PHP 5.6 or newer (PHP 7.3 recommended)
  • All of the official add-ons require XenForo 2.1.
  • xenforo_2.1.8-Patch-2_upgrade_NULL_VNXF.zip
    12.5 MB · Lượt xem: 161
  • xenforo_2.1.8-Patch-2_full_NULL_VNXF.zip
    12.3 MB · Lượt xem: 502
WOWLivex
Lỗi rồi bác ơi @PVS
Bạn cài bản full hay upgrade vậy.
Mình update lại file rồi, bạn check lại nha.
thahtrung06
Lỗi rồi bác ơi @PVS
Công cụ Check for upgrades chỉ sử dụng khi bạn đã mua bản quyền xenforo nhé! Bạn **** mà bạn dùng công cụ này để cập nhật bản mới sẽ bị lỗi như trên. Mình không có cách nào để khắc phục lỗi này hay ẩn thông báo lỗi này dù có cập nhật lên phiên bản Xenforo mới nhất thì vẫn hiện thông báo lỗi đó.
WOWLivex
Bạn sai rồi nhé, công cụ Check for upgrade nào ở đây nè. Cài xong vào Admin Dashboard là nó báo lỗi liền nhé. Mình đã thông báo và bạn @PVS đã sửa. Mình cũng đã confirm là sau khi sửa cài vào OK. Bạn nên xem lại.
penny2020
à không lỗi, hôm qua mình cài qua bật cloud mà nó không chuyển hướng khiến bị chuyển hướng nhiều lần, truy cập link install là ok, mà bản này k biết ổn định không, mình hạ xuống 2.0.1
Kỳ nhỉ, mình vừa up bên site demo thấy không hiện bảng như vậy.
vanthoi_it
Bạn check thử xem file up lên có đúng cái này không :
Mình đã thử đẩy code lên 2 lần rùi mà nó vẫn hiện
Bạn thử down file upgrade về rồi đè lên xem sao.
Bạn thử tải file này về up đè lên xem sao. Nhớ install lại nhé.
  • xenforo_2.1.8-Patch-2_FIX_NULL_VNXF.zip
    212 KB · Lượt xem: 6
vanthoi_it
Sao phải khổ thế, thay mỗi dòng đó cứ nói mình, mình fix rồi test cho. Up lên chi cho tốn time vậy.
Có điều là tình hình ko có gì thay đổi cả :D
vanthoi_it
Tạm thời chán nó rồi chơi trò mới. Vì nó cũng chả ảnh hưởng gì đến forum
Mọi người ai bị thì làm theo cách sau:
Bước 1: Vào Phrase tìm: upgrade_check_errors_must_be_resolved
Bước 2: Dán đoạn sau vào:
<style>
        body > div.p-body-container > div > div > main > div.blockMessage.blockMessage--error.blockMessage--iconic {display: none;}
    </style>
<span class="hien_nua_di">The following issues must be resolved as soon as possible. Once they have been resolved, <a href="{link}">check for upgrades again</a> to confirm</span>
Thế là nó sẽ ẩn cái chướng mắt đó đi :p
Nhưng không ẩn các lỗi khác của diễn đàn!
