Released 2x XenForo 2.2.10 Patch 1 Released | XenForo 2.2.10 Patch 1 Released **** | Add-ons Released
XenForo 2.2.10 is now available for all licensed customers to download. We strongly recommend that all customers running previous versions of XenForo 2.2 upgrade to this release to benefit from increased stability.
This version contains a fix for an issue whereby outgoing requests from the server running XenForo could be tricked into accessing web-accessible resources on the local network. The scope to exploit this issue is limited within the core and first-party add-ons.
2.2.10 will be one of the last releases of the 2.2.x series before we move 2.3.0 to beta, but we do have a handful of things coming late to 2.2.x before that happens, including some enhanced cookie consent features to comply with the ever-evolving field of privacy legislation, and some enhanced performance-boosting functionality for Entities and Finders for developers. More details on those soon.
Of course, 2.2 will continue to be supported and maintenance releases will be made periodically throughout the 2.3.0 beta process and as always we will issue patches and fixes for any critical issues in 2.2 even after 2.3 becomes our primary, supported version.
Some of the changes in XF 2.2.10 include:
  • Require values for old/new changelog values
  • Properly handle **** values within the Arr::stringToArray() function
  • Remove extraneous space when generating a one-time password URL
  • Support rebuilding daily stats from the command line
  • Add additional indexes for the active and expired user upgrade tables
  • Remove superfluous code setting aria-label for tooltips
  • Add lazy loading attribute to resource icons
  • Pass an index hint when performing certain IP lookups
  • core_block.less
  • poll_create
  • poll_edit
  • poll_macros
  • tag_macros
  • widget_forum_statistics
As always, new releases of XenForo are free to download for all customers with active licenses. You may now upgrade from your admin control panel or grab the new version from the customer area.
Current requirements​
  • PHP 7.0 or newer (PHP 8.0 recommended)
  • xenforo_2.2.10-Patch-1_full_NULL_VNXF.zip
    13.6 MB · Lượt xem: 252
  • xenforo_2.2.10-Patch-1_upgrade_NULL_VNXF.zip
    13.6 MB · Lượt xem: 118
Mr Black
Sao mình tải file upgrade, lúc vào đường dẫn install báo lỗi "The requested page could not be found."
dangvanbac
tko
E mới lập forum thì cài 2 file đính kèm này theo thứ tự ra sao các bác nhỉ, cài cái 1 xong cài cái 2 hay sao ạ?
dangvanbac
Bạn cài mới thì upload mỗi file xenforo_2.2.10-Patch-1_full_NULL_VNXF.zip thôi nhé, còn file kia là file Upgrade, dành cho những forum cập nhật lên phiên bản mới.
Reactions: tko
tko
E cảm ơn ạ, cho e hỏi e vừa cài, tới bước tạo admin thì e điền xong admin, pass, mail rồi nhấn "Create administrator" thì bị báo lỗi 405 Not Allowed thì xử lý sao đc ạ? E cảm ơn
dangvanbac
Bạn tiến hành tải file cài đặt (chứ không phải file upgrade), sau đó đọc theo hướng dẫn bên dưới làm theo nhé. Nếu đã upload file rồi thì xóa hết đi, xóa trống cả database nữa nhé.
Link hướng dẫn cài mới: https://vnxf.vn/manual20/install-upgrade/index.html#2-uploading
Reactions: tko
tko
E làm được rồi ạ, cảm ơn bác nhiều. Cho e hỏi e muốn làm được khung "Hidden Content" là khung màu đỏ như trong trang này thì dùng addon hay cách nào đc ạ? E cảm ơn:
dangvanbac
Bạn tham khảo:
- https://vnxf.vn/threads/mmo-hide-bb...bbcode-an-noi-dung-cho-xenforo-2-2-2-4.27614/
- https://vnxf.vn/threads/xengentr-hidden-content-an-noi-dung-xenforo-2-1-2-4.26266/
P/s: Chịu khó tìm hiểu thêm các Addons nhé bạn. Xem thêm ở mục Addons của VNXF nhé
Reactions: tko
tko
Cảm ơn bác nhiều. Mà chắc e phải tìm thêm vì hình như chưa phải đúng cái e đang tìm. Dù sao cũng cám ơn bác rất nhiều
tko
Đã cài được ạ, cảm ơn mọi người rất nhiều
tko
Thanks all
