Released 2x XenForo 2.2.10 Released | XenForo 2.2.10 Released **** | Add-ons Released
XenForo 2.2.10 is now available for all licensed customers to download. We strongly recommend that all customers running previous versions of XenForo 2.2 upgrade to this release to benefit from increased stability.
This version contains a fix for an issue whereby outgoing requests from the server running XenForo could be tricked into accessing web-accessible resources on the local network. The scope to exploit this issue is limited within the core and first-party add-ons.
2.2.10 will be one of the last releases of the 2.2.x series before we move 2.3.0 to beta, but we do have a handful of things coming late to 2.2.x before that happens, including some enhanced cookie consent features to comply with the ever-evolving field of privacy legislation, and some enhanced performance-boosting functionality for Entities and Finders for developers. More details on those soon.
Of course, 2.2 will continue to be supported and maintenance releases will be made periodically throughout the 2.3.0 beta process and as always we will issue patches and fixes for any critical issues in 2.2 even after 2.3 becomes our primary, supported version.
Some of the changes in XF 2.2.10 include:
  • Require values for old/new changelog values
  • Properly handle **** values within the Arr::stringToArray() function
  • Remove extraneous space when generating a one-time password URL
  • Support rebuilding daily stats from the command line
  • Add additional indexes for the active and expired user upgrade tables
  • Remove superfluous code setting aria-label for tooltips
  • Add lazy loading attribute to resource icons
  • Pass an index hint when performing certain IP lookups
  • core_block.less
  • poll_create
  • poll_edit
  • poll_macros
  • tag_macros
  • widget_forum_statistics
As always, new releases of XenForo are free to download for all customers with active licenses. You may now upgrade from your admin control panel or grab the new version from the customer area.
Current requirements​
  • PHP 7.0 or newer (PHP 8.0 recommended)
  • xenforo_2.2.10_upgrade_NULL_VNXF.zip
    13.6 MB · Lượt xem: 54
  • xenforo_2.2.10_full_NULL_VNXF.zip
    13.6 MB · Lượt xem: 131
dangvanbac
Đã lên 2.2.10, mọi thứ hoạt động bình thường.
dhv49
Có bác nào bị như này không? Xin cách khắc phục
dangvanbac
Mình cũng có, nhưng cái này không vấn đề gì đâu bác. XF2 nó chạy quét lic, ta dùng bản **** thì lấy đâu ra lic. Cứ dùng bình thường thôi :)
dhv49
Mấy bản trước không bị lỗi ntn, giờ nâng cấp nên bị. Lâu không nâng nên hơi bỡ ngỡ với lỗi này bác. Vậy vẫn full chức năng à bác?
phucvandinh
Không khuyến khích anh em lên bản này do bản này dính một số lỗi, đợi bản vá rồi hãy lên.
dangvanbac
Vậy đầy đủ bác nhé, cứ lên đi, không ảnh hưởng gì đâu.
dangvanbac
Có bản XenForo 2.2.10 Patch 1 rồi đó bác, fix một số lỗi ảnh hưởng đến một số người dùng. Xem thêm: https://vnxf.vn/threads/xenforo-2-2...patch-1-released-****-add-ons-released.30277/
nhanh quá chưa kịp update luôn. giờ còn dùng 2.8
dotruongvan202
E update lên nó báo thế này cả vài tiếng rồi thì là lỗi hay là tính năng vậy các bác
dotruongvan202
Nâng cấp khác, cài mới khác nhé! Nếu bạn xóa file này thì sẽ là cài mới forum, tất cả dữ liệu trước đó sẽ mất hết.
Bác xóa file install-lock.php đi rồi update lại xem nhé, có bản XenForo 2.2.10 Patch 1 rồi thì bạn tải phần Update của nó rồi update lên xem sao
e làm lỗi mất giờ restore về phiên bản cũ thì dính lỗi 503 này
các bác cứu e phát
dangvanbac
Khả năng bác chủ topic chơi bản Ins roài.
