Addon 2x (AJAX) Advanced Forum Stats
MacKen
(AJAX) Advanced Forum Stats 1.2
Introducing a classic add-on so many forums can't live without..
In 3 words: simple, clean, flexible
This add-on will display the following stats:
  1. Latest Posts
  2. Latest Threads
  3. Hottest Threads (based on most replies in set interval)
  4. Most Viewed Threads
  5. Latest Forum News
  6. Latest Members
  7. Most Liked Users
  8. Top Thread Starters
  9. Most Liked Threads
  10. Most Popular Forums
  11. Top Resources
  12. Latest Resources
  13. Plus Many More in future updates - we're open to suggestions
Auto-Refresh
What's the point of having stats if they can't auto-refresh, right?
- Stats will auto-refresh every X seconds (specified via admin setting)
- Don't want to wait for the next refresh? No problem, simply click "Refresh Now"
- Each user can also individually enable/disable auto-refresh
Global Template/Custom Locations Support
- Easily insert into any template/page by copying 1 line of code
Full Control
- Specify user groups allowed to view stats
- Display the stats panel above or below the forums
- Enable/disable each stat individually
- Specify the amount of results to display per stat
- Only show results from X forums, each stat has the option to specify which forum(s) to include
- Exclude specific forums
- Show/Hide Thread Prefixes
- Set cutoffs in days
Multi-Column Layout
Want to display some stats on the mini column and others on the main column?
You're free to choose the position and order that's best for you
Show/Hide Stats Panel
You can show or hide the stats panel with a single click, it'll remember your choice.
How does it benefit you?
  • Instantly boost user engagement
  • Find 10+ types of advanced stats and the updates you need in one place
  • No more having to to constantly refresh the page
  • Enhance your forum's attractiveness
  • Quick and easy setup
Full Features
  • Fully mobile responsive
  • User group permissions
  • Caching system
  • Stats panel position: above/below forums
  • Refresh time interval (in seconds)
  • AJAX Pop-up thread previews on hover
  • Rich Username Support
  • Adjust the width of each column
  • Enable/disable data loading animation
  • Enable/disable each stat individually
  • Adjust column position for each stat
  • Adjust display order for each stat
  • Adjust amount of results to display for each stat
  • Only include X forums for each stat
  • Thread results include thread prefix
  • Highlighted unread threads/posts
  • XenForo Resource Manager Support
  • Full phrase support
Feedback / reviews / ratings are always appreciated!
Enjoy
    42 bytes · Lượt xem: 42
    42 bytes · Lượt xem: 38
  • ajax-advanced-forum-stats-12.rar
    64 KB · Lượt xem: 202
Sừ kê :)), tks bạn
laan
Nó là cái gì zậy -_-
add-on thống kê cho xen2 nha bạn
luonggiawatch
mình dùng xen 2.0.7 thì up file lên kiểu gì bạn nhỉ, không hiểu nữa
secpol
Bạn up toàn bộ file trong folder upload lên ngang hàng với admin.php rồi vào chỗ addons trong ACP để cài.
quanken
Không đổi được tên theo chuyên mục. Hơi tù @@
