Styles Brivium - Tellurium - Material Design XenForo Style 1.5.22
singh
Brivium - Tellurium - Material Design XenForo Style 1.5.22 bản cuối cùng. lợm được trên mạng đang cài thử. Quét virus online không phát hiện gì.
Tellurium is an amazing combination between the XenForo platform and Material Design of Google. You can easily experience the interaction with the users just in one screen.
Check out live preview at here.
tellurium-thumb-3-png.7991
Tellurium brings in itself all the characteristics needed to have with a “Material style”:
- Using an unique color for the whole web “dark blue”, etc ...
- The visual details are delightful, and the paradigmatic underpinnings — that interfaces are three-dimensional constructions, composed of layers of “physical” components — are refreshingly novel.
- Flat, simple but understandable icons: The navigation bar is simplified maximum to create an easy experience for new users.
- Interface is flat, has little or no color transitions, with or without black shadow effects
- All of Menus, buttons, scripts ... have much empty blanks so it looks airy.
User Notification Center
Member Lists / Member Card
Quick Create Thread Action Button (This add-on included on Style package which valued $15)
Thread View / BBcodes Effects
Search Box Effects
Member Register / Login Box
  • tellurium-material-design-xenforo-style-1.5.22.zip
    2.5 MB · Lượt xem: 40
