XenForo 1.5.11 Released
Today, we are pleased to release XenForo 1.5.11. This release fixes a number of bugs and issues that were found since the release of 1.5.10. As this is a maintenance release, the vast majority of the focus was an increase in stability.Notably, we have adjusted the exact procedure used for generating secure random data to adhere to current best practices. If your system does not have access to a modern and fully secure approach to generating random data, we will now warn you during installation/upgrades and display a message indicating this in the control panel. If possible, we recommend using PHP 7 to take advantage of the new features for generating random numbers. Thanks to @rugk for bringing this to our attention.
Some of the changes in 1.5.11 include:
- Workaround a Firefox bug where the Flash uploader shows as an opaque white box.
- Support redirects in the image proxy and link title conversion process (while maintaining security).
- Improve autolinking when there are special characters (brackets and similar) immediately after a URL.
- Maintain ICC profiles when resizing with ImageMagick.
- Add extra verification to quote alerts to ensure you only get an alert when the quote is attributed to you.
- The "Facebook Open Graph Logo" style property is now simply "Open Graph Logo" to indicate that it's usage is more generic.
- Fix an HTML error in editor dialogs.
- Fix advanced background-repeat CSS being improperly converted to style property values.
- Add multi-submission prevention to report commenting to prevent accidental double clicks.
- Change the default user agent on outgoing HTTP requests to indicate XenForo and the triggering installation URL.
- Adjust the HTTP response code on malformed proxy output requests to a general 400 error to indicate the client sent a bad request.
- Ensure that when files are dragged into the rich text editor, they are uploaded one by one rather than simultaneously.
- Ensure that leading whitespace is maintained when pasting preformatted text into the rich text editor.
The following templates have had changes:
- attachment_editor.css
- editor_dialog_code
- editor_dialog_image
- editor_dialog_link
- editor_dialog_media
- report_view
Please note that we are now formally recommending that you upgrade to PHP 5.4 or newer. Our intention with XenForo 2.0 is to require PHP 5.4 or newer. If you are running PHP 5.3 or 5.2, you will receive a warning when installing or upgrading XenForo.
All customers with active licenses may now download the new version from the customer area.
P/S:
- ae test dùng nhé. chưa có thời gian test nữa. sẽ có hình demo sau nhé.
- pass giải nén: vnxf.vn.
- Thanks all
Hình ảnh cho mọi người nhé. Mọi thứ ok nhé các ae. Hình upgrwde nhé. AE nào cài mới thì dùng bản FULL nhé. Test giúp luôn nhé.
