Bước 1: Download Social Locker for jQuery v1.7.6 (file đính kèm) và up lên host giải nén.
Bước 2: Mở template page_container_js_head và thêm vào dưới cùng.
<!-- [INSTALATION] -->
<!-- libraries (copy and check path correctness) -->
<script src="[COLOR=#ff0000]http://buidoi.net/js/js/libs/jquery.ui.highlight.min.js[/COLOR]"></script>
<!-- social locker (copy and check path correctness) -->
<script src="[COLOR=#ff0000]http://buidoi.net/js/js/jquery.onp.sociallocker.1.7.6.js[/COLOR]"></script>
<link type="text/css" rel="stylesheet" href="[COLOR=#ff0000]http://buidoi.net/js/css/jquery.onp.sociallocker.1.7.6.min.css[/COLOR]" />
<link href="[COLOR=#ff0000]http://buidoi.net/js/js/css/examples.css[/COLOR]" rel="stylesheet" type="text/css" />
<!--[if IE]><script src="http://html5shiv.googlecode.com/svn/trunk/html5.js"></script><![endif]-->
// Notice: read the documentation that comes with the plugins to get more details
// IMPORTANT: this is an obligatory wrapper, it runs after loading a page
jQuery(document).ready(function ($) {
// use your own selector to choose content what you want to lock
$("#default-usage .to-lock").sociallocker({
// IMPORTANT: remove the demo option. It makes the locker appears
// every time even if you unlocked the one already.
demo: true,
// text that appears above the social buttons
// any html tags available, for example: "<strong>My locker message</strong>"
text: {
header: "XÁC NHẬN ĐĂNG KÝ!",
message: "Hãy Like - Google+ - Share để tiếp tục đăng ký!"
// a theme name that will be used,
// by default available: secrets, dandyish, glass
theme: "secrets",
// the order of the social buttons
// you can remove this option to use the default order
// available buttons:
// - facebook: facebook-like, facebook-share,
// - twitter: twitter-tweet, twitter-follow,
// - google: google-plus, google-share (experimental, doesn't work in IE and Opera).
buttons: {
order: [
"twitter-tweet"
,"facebook-like"
,"google-plus"
// facebook options
// check out the documentation to learn more about facebook options
facebook: {
appId: "[COLOR=#ff0000]247582348697830[/COLOR]",
like: {
// url to like
url: "[COLOR=#ff0000]http://buidoi.net[/COLOR]"
twitter: {
tweet: {
// url to tweet
google: {
plus: {
// url to plus +1
</script>
* CHÚ Ý NHỚ SỬA URL VÀ ID APP FACEBOOK
Bước 3: Mở template register_form thay toàn bộ bằng code sau (áp dụng cho xenforo 1.4.x)
<xen:title>{xen:phrase sign_up}</xen:title>
<article id="default-usage">
<section class="example">
<div class="to-lock" style="display: none;">
<form action="{xen:link 'register/register'}" method="post" class="xenForm AutoValidator"
data-fieldValidatorUrl="{xen:link register/validate-field}"
data-normalSubmit="1"
<xen:if is="{$errors}">
<div class="errorPanel">
<h3 class="errorHeading">{xen:phrase please_correct_following_errors}:</h3>
<div class="baseHtml errors">
<ol>
<xen:foreach loop="$errors" value="$error">
<li>{xen:raw $error}</li>
</xen:foreach>
</ol>
</xen:if>
<dl class="ctrlUnit limited">
<dt><label for="ctrl_username">{xen:phrase name}:</label></dt>
<dd>
<input type="text" name="username" value="" class="textCtrl" id="ctrl_username" autocomplete="off" />
<p class="explain">{xen:phrase please_leave_this_field_blank}</p>
</dd>
</dl>
<dl class="ctrlUnit">
<dt><label for="ctrl_{$fieldMap.username}">{xen:phrase name}:</label></dt>
<dd>
<input type="text" name="{$fieldMap.username}" value="{$fields.username}" class="textCtrl" id="ctrl_{$fieldMap.username}" autofocus="true" autocomplete="off" />
<p class="explain">{xen:phrase this_is_name_that_will_be_shown_with_your_messages}</p>
</dd>
</dl>
<xen:if is="mt_rand(0, 2) == 1">
<dt><label for="ctrl_{$fieldMap.email_hp}">{xen:phrase email}:</label></dt>
<dd>
<input type="email" name="{$fieldMap.email_hp}" value="" dir="ltr" class="textCtrl" autocomplete="off" id="ctrl_{$fieldMap.email_hp}" />
</dd>
</dl>
</xen:if>
<dt><label for="ctrl_{$fieldMap.email}">{xen:phrase email}:</label></dt>
<dd>
<input type="email" name="{$fieldMap.email}" value="{$fields.email}" dir="ltr" class="textCtrl" id="ctrl_{$fieldMap.email}" />
</dd>
</dl>
<fieldset>
<dt><label for="ctrl_password">{xen:phrase password}:</label></dt>
<dd>
<input type="password" name="password" class="textCtrl OptOut" id="ctrl_password" autocomplete="off" />
</dd>
</dl>
</xen:if>
<dt><label for="ctrl_{$fieldMap.password}">{xen:phrase password}:</label></dt>
<dd><input type="password" name="{$fieldMap.password}" class="textCtrl OptOut" id="ctrl_{$fieldMap.password}" autocomplete="off" /></dd>
</dl>
<dt><label for="ctrl_{$fieldMap.password_confirm}">{xen:phrase confirm_password}:</label></dt>
<dd>
<input type="password" name="{$fieldMap.password_confirm}" class="textCtrl OptOut" id="ctrl_{$fieldMap.password_confirm}" />
<p class="explain">{xen:phrase enter_your_password_in_first_box_and_confirm_it_in_second}</p>
</dd>
</dl>
<dt><label for="ctrl_{$fieldMap.password_confirm_hp}">{xen:phrase confirm_password}:</label></dt>
<dd>
<input type="password" name="{$fieldMap.password_confirm_hp}" class="textCtrl OptOut" id="ctrl_{$fieldMap.password_confirm_hp}" />
</dd>
</dl>
</xen:if>
</fieldset>
<dt>{xen:phrase gender}:</dt>
<dd>
<ul>
<li><label><input type="radio" name="{$fieldMap.gender}" value="male" {xen:checked "{$fields.gender} == 'male'"} /> {xen:phrase male}</label></li>
<li><label><input type="radio" name="{$fieldMap.gender}" value="female" {xen:checked "{$fields.gender} == 'female'"} /> {xen:phrase female}</label></li>
<li><label><input type="radio" name="{$fieldMap.gender}" value="" {xen:checked "!{$fields.gender}"} /> ({xen:phrase unspecified})</label></li>
</ul>
</dd>
</dl>
<xen:include template="helper_birthday_row_register" />
<xen:if is="{$xenOptions.registrationSetup.requireLocation}">
<dt>
{xen:phrase location}:
<dfn>{xen:phrase required}</dfn>
</dt>
<dd>
<input type="text" name="location" value="{$fields.location}" class="textCtrl" />
</dd>
</dl>
</xen:if>
<xen:set var="$honeyPotPosition" value="{xen:helper rand, 0, 2}" />
<xen:if is="{$customFieldHoneyPot} && {$honeyPotPosition} == 1">
<xen:include template="custom_field_edit">
<xen:set var="$customFieldInputName" value="{$fieldMap.custom_fields}" />
<xen:set var="$field" value="{$customFieldHoneyPot}" />
<xen:set var="$customFieldExtraClass" value="limited" />
</xen:include>
</xen:if>
<xen:include template="custom_fields_edit">
</xen:include>
<xen:if is="{$customFieldHoneyPot} && {$honeyPotPosition} == 2">
</xen:include>
</xen:if>
<dl class="ctrlUnit" style="display: none">
<dt><label for="ctrl_{$fieldMap.timezone}">{xen:phrase time_zone}:</label></dt>
<dd>
<select name="{$fieldMap.timezone}" class="textCtrl {xen:if $fields.timezoneAuto, 'AutoTimeZone'} OptOut" id="ctrl_{$fieldMap.timezone}">
<xen:foreach loop="$timeZones" key="$identifier" value="$name">
<option value="{$identifier}" {xen:selected "{$identifier} == {$fields.timezone}"}>{$name}</option>
</xen:foreach>
</select>
</dd>
</dl>
<xen:if hascontent="true">
<fieldset>
<xen:contentcheck>
<xen:include template="helper_captcha_unit" />
</xen:contentcheck>
</fieldset>
</xen:if>
<dl class="ctrlUnit submitUnit">
<dt></dt>
<dd>
<xen:set var="$timerHtml"><xen:if is="{$xenOptions.registrationTimer}">
<span id="RegTimer">({xen:phrase please_wait_x_seconds, "seconds=<span>{$xenOptions.registrationTimer}</span>"})</span>
</xen:if></xen:set>
<xen:if is="{$tosUrl}">
<ul>
<li>
<div class="text">{xen:phrase i_agree_to_terms_and_rules, 'checkbox=<input type="checkbox" name="agree" value="1" id="ctrl_agree" class="Disabler" />', 'terms_attributes=href="{$tosUrl}" target="_blank"'}</div>
<ul id="ctrl_agree_Disabler">
<li><input type="submit" value="{xen:phrase sign_up}" accesskey="s" class="button primary" id="SubmitButton" /> {xen:raw $timerHtml}</li>
</ul>
</li>
</ul>
<xen:else />
</xen:if>
</dd>
</dl>
<input type="hidden" name="_xfToken" value="{$visitor.csrf_token_page}" />
<input type="hidden" name="reg_key" value="{$regKey}" />
</form>
</section>
</article>
(function($) {
$(function() {
var rt = $('#RegTimer'), s = rt.find('span'), t = parseInt(s.text(), 10),
sub = $('#SubmitButton'),
i = setInterval(function() {
t--;
if (t <= 0) {
rt.hide();
clearInterval(i);
} else {
s.text(t);
}, 1000);
var f = function(e) {
if (t > 0) {
e.preventDefault();
sub.click(f);
sub.closest('form').submit(f);
})(jQuery);
</script>
</xen:if>
Nguồn: Lê Tí - Buidoi.net
