MacKen
Description:
This addon will allow you to modify the text that is copied from your forum. You may append a "Read More at ...", or trim the copied content to a desired length and then append your text. If you want you may disable copy function altogether on your forum.
Features:
There are three modes:
- Append Mode -- Copied text is modified by appending/prepending text ssetup in the AdminCP
- Trim Mode -- Before Appending anything, the copied text is cut down to the desired text length which is setup in the AdminCP
- Don't Copy -- If you want to disable copying from your forum, this is your friend.
All three modes can be set separately for guests and logged in users.
Installation:
Use Add-On Installer by Chris Deeming or the following:
Go to Option from AdminCP and then 'Copy Paste Read More'. Here you can specify the modes and append text as well as trim length.
Technical details:
Features:
Installation:
- The zip file contains an "upload" folder. Upload the contents of the folder in the root XF folder, thereby creating 'library/CopyPasteReadMore' and directory on your server.
- The zip file contains an XML file. Import the XML in your Admin CP
Technical details:
- As such, this addon can be disabled or uninstalled very easily without any lasting effects.
- This addon has 0 query overhead.
- This addon does not make any changes to your database
