onlyonelove
Sau khi nâng cấp MySQL 8.0 cho server thì trang home của XenPorta không hiển thị và gặp lỗi, có ai bị hoặc biết cách xử lý lỗi này không.
Hiện mình đang xài bản XenPorta 1.2.2b mới nhất
https://xenforo.com/community/resources/8wr-xenporta-portal-pro.3894/
An exception occurred: Mysqli prepare error: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'groups, IF(EWRporta2_widopts.widopt_id, EWRporta2_widopts.ctime, EWRporta2_' at line 5 in /var/www/nopviet/library/Zend/Db/Statement/Mysqli.php on line 77
Zend_Db_Statement_Mysqli->_prepare() in Zend/Db/Statement.php at line 115
Zend_Db_Statement->__construct() in Zend/Db/Adapter/Mysqli.php at line 381
Zend_Db_Adapter_Mysqli->prepare() in Zend/Db/Adapter/Abstract.php at line 478
Zend_Db_Adapter_Abstract->query() in XenForo/Model.php at line 219
XenForo_Model->fetchAllKeyed() in EWRporta2/Model/Widlinks.php at line 66
EWRporta2_Model_Widlinks->getWidlinksByLayoutId() in EWRporta2/ViewPublic/Global.php at line 51
EWRporta2_ViewPublic_Global->prepareParams() in XenForo/ViewRenderer/Abstract.php at line 222
XenForo_ViewRenderer_Abstract->renderViewObject() in XenForo/ViewRenderer/HtmlPublic.php at line 71
XenForo_ViewRenderer_HtmlPublic->renderView() in XenForo/FrontController.php at line 624
XenForo_FrontController->renderView() in XenForo/FrontController.php at line 176
XenForo_FrontController->run() in /var/www/nopviet/index.php at line 13
Lỗi khi nâng cấp
bởi Hinh Chu,
