MacKen
Premium upgrade:
This XF2 add-on along with the entire collection can be purchased for $25.00 USD. Your Premium upgrade will allow you to download as many XF2 add-ons as you like for one year. Please see the entire collection located in the Resources area at this URL:
https://www.xf2addons.com/
Note: all my XF1 add-ons are still 100% free and are supported by donations.
Description:
Audio player which plays attached .mp3 audio files.
Automatically inserts an audio player for each .mp3 attachment.
(Example of Audio plus player in a post)
Installation:
Setup step 3:
This add-on requires the Unregistered / Unconfirmed user group to have "View attachments to posts" setting set to "Yes".
Questions and Answers:
Q: I get the following error message after uploading a file, "There was a problem uploading your file".
A: This means your php.ini maximum upload setting needs to be increased.
Q: Will this add the audio player to any previous posts with .mp3 attachments?
A: No. To make older posts show the audio player, you will need to edit and save the post.
Q: Can you make this permission based?
A: No.
Q: My error.log show a problem with file_get_contents command.
A: Make sure allow_url_fopen is enabled in PHP.
Q: Will this work in Conversation posts?
A: No.
Description:
Installation:
- Download Andy-AudioPlus-1.2.zip and unzip it.
- Copy the src/addons/Andy/AudioPlus directory to your server.
- From the Admin Control Panel Install the add-on.
- Create a post.
- Upload a .mp3 audio file using the "Upload a File" button.
- Save Changes.
- Audio player is automatically inserted into message.
- Click play button to listen to audio.
- Create a /misc/ folder in your web root.
- Upload the following file Andy/AudioPlus/audioplus.php to your /misc/ folder.
- In order to do the next step you need to put the forum into debug mode. Add $config['debug'] = true; to your config.php file.
- In the Admin control panel Admin control panel -> Content -> Custom BB codes update the Custom BB Code. The HTML replacement needs to reflect your domain and location of the /misc/ folder.
- Remove the $config['debug'] = true; from your config.php file.
Setup step 3:
- In the Admin control panel, update "Maximum Attachment File Size (KB)" to 3072, this will allow a maximum of 3MB audio files to be uploaded.
- In the Admin control panel, update "Allowed attachment file extensions" to include mp3 files.
A: No.
A: No.
