nhuttran913
CHo mình hỏi là mình chuyển HTPP sang HTPPS//WW.
mình sử dụng
mọi người ai biết giúp mình với, chuyển những link từ HTTPS sang HTTPS//WWW.
mình sử dụng
# Mod_security can interfere with uploading of content such as attachments. If you
# cannot attach files, remove the "#" from the lines below.
#<IfModule mod_security.c>
# SecFilterEngine Off
# SecFilterScanPOST Off
#</IfModule>
ErrorDocument 401 default
ErrorDocument 403 default
ErrorDocument 404 default
ErrorDocument 405 default
ErrorDocument 406 default
ErrorDocument 500 default
ErrorDocument 501 default
ErrorDocument 503 default
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteCond %{HTTPS} off
RewriteRule (.*) https://%{HTTP_HOST}%{REQUEST_URI} [L,R=301,NE]
RewriteCond %{HTTP_HOST} !^www. kenhvantai\ .net$ [NC]
RewriteRule ^(.*)$ http://www.kenhvantai.net/$1 [R=301,L,QSA]
# If you are having problems with the rewrite rules, remove the "#" from the
# line that begins "RewriteBase" below. You will also have to change the path
# of the rewrite to reflect the path to your XenForo installation.
#RewriteBase /xenforo
# This line may be needed to enable WebDAV editing with PHP as a CGI.
RewriteRule ^.*$ - [NC,L]
</IfModule>
