Highlight threads with polls
Vnxf.vn - This is a simple template edit which will allow you to highlight threads with polls in the thread list.
Useful if you don't want to use a prefix.
The instructions below apply to XenForo 1.4.
The template code may be different in earlier versions of XenForo, but the principle is the same.
The template you need to edit is the thread_list_item template.
You can of course make the edit wherever you wish in the template - this first example has it before the prefix.
Look for these two lines of code:
<xen:if is="{$showSubscribeOptions}"><input type="checkbox" name="thread_ids[]" value="{$thread.thread_id}" /></xen:if>
<xen:if is="{$thread.prefix_id}">
Add the following code between the two lines:
<xen:if is="{$thread.discussion_type} == 'poll'">
    Poll
</xen:if>
Like so:
[COLOR=#ff8000]<xen:if is="{$thread.discussion_type} == 'poll'">
    Poll
</xen:if>[/COLOR]
The result is this:
Of course you can replace the word 'Poll' with a phrase, an image, style it to suit, etc.
You could even do something like this:
Look for this line of code:
<li id="thread-{$thread.thread_id}" class="discussionListItem {$thread.discussion_state}{xen:if '!{$thread.discussion_open}', ' locked'}{xen:if {$thread.sticky}, ' sticky'}{xen:if {$thread.isNew}, ' unread'}{xen:if {$thread.prefix_id}, ' prefix{$thread.prefix_id}'}{xen:if {$thread.isIgnored}, ' ignored'} {xen:if $thread.thread_is_watched, threadWatched} {xen:if $thread.forum_is_watched, forumWatched}" data-author="{$thread.username}">
Add the following code, which adds a new discussionListItemPoll class:
{xen:if "{$thread.discussion_type} == 'poll'", ' discussionListItemPoll'}
Like so:
<li id="thread-{$thread.thread_id}" class="discussionListItem {$thread.discussion_state}{xen:if "{$thread.discussion_type} == 'poll'", ' discussionListItemPoll'}{xen:if '!{$thread.discussion_open}', ' locked'}{xen:if {$thread.sticky}, ' sticky'}{xen:if {$thread.isNew}, ' unread'}{xen:if {$thread.prefix_id}, ' prefix{$thread.prefix_id}'}{xen:if {$thread.isIgnored}, ' ignored'} {xen:if $thread.thread_is_watched, threadWatched} {xen:if $thread.forum_is_watched, forumWatched}" data-author="{$thread.username}">
Then add the class to the EXTRA.css template with the styling you wish:
.discussionListItemPoll
    border: 1px solid orange !important;
Or combine the two:
As you can see, there are numerous possibilities.
Just use this as a guide to achieve the result you want.
