61,854 52 5
[BP] MostEverOnline 1.0.3
Compatible XF 2.x versions
2.0
License
GNU General Public License (open source)
Visible branding
No
This is a free add-on made by me that will show the counts of the most users that have ever been online. It includes counts for all users, members, and guests.
You have the option to display counts for any or all of the 3. Totals, members, or guests via permissions. . You can choose to display them right inside the members online widget under the total visitors. You can also display it as a widget, just be sure to create your widget and make sure the permission isn't set to off.
When you first install the add-on all the display permissions for the add-on specifically are set to default yes. To enable the counts under the members online widget simply go to options->[BP] MostEverOnline-> and select the option for it. Check the box and click save. To display the widget go to appearance -> widgets ->add widget -> widget definition -> then select "Most Users Ever Online". You can place the widget anywhere you'd like. The add-on is fully phrased so you can change the text by going to appearance -> phrases and selecting the add-ons phrases
This add-on also runs via a Cron task. The counts are updated every minute. You can manually run the cron task by finding the Most Users Ever Online run task and running it.
Feature list:
- Counts for Most Total Users Ever Online
- Counts for Most Total Members Ever Online
- Counts for Most Total Guests Ever Online
- Option to place inside Members Online under total visitors
- Option to create a Widget with the Counts
- Permission to select whether to display any of the counts for selected usergroups
- Permission to choose who or what usergroup can see the widget
- Fully phrased
To install be sure to upload the contents of the Upload directory to the root of your Xenforo installation. After you upload the files go to your admin panel then go to and click the add-on section and click install. Be sure to upload the files correctly.
For more information on how to install add-ons refer to this documentation -> https://xenforo.com/xf2-docs/manual/add-ons/#installing-or-upgrading-an-add-on
If you have any questions I will be sure to answer them. I worked really hard on this and hope you like the add-on.
Convert Threads to Resources 1.0.2
2.0
Additional requirements
Resource Manager 2.0.3
License
MIT Licence
Visible branding
No
This add-on allows you to convert the first post of an existing forum thread into a resource manager resource. The newly created resource will be posted under the original thread starter and will retain the original thread date. The first post of the converted thread will be updated to link to the newly created resource.
All attached images will be associated to the newly created resource. The first non-image attachment will be converted to a resource manager attachment. Any additional non-image attachments will not be converted and will no longer be accessible!
In order to convert a thread to a resource category, the resource category must have at least the allowed resource type option of "Fileless".
Converting Threads
An individual thread can be converted by clicking “Thread Tools” and selecting the “Convert to Resource” option.
A batch of threads can also be converted by selecting them and then selecting the “Convert to Resources” option. (Only Admins and Moderators can use Batch convert)
Image attachments from the converted thread appear in the resource
Add-on developed by @truonglv
Repository: https://github.com/luutruong/ThreadResource
2.0
License
MIT Licence
Visible branding
No
Converting Threads
phankt
admin tải giúp em add on này với ah
https://xenforo.com/community/resources/xenmax-limit-post-link.5980/
Shu Sakamaki
Đây bạn: https://vnxf.vn/code-mo-rong-code-editor-cho-xenforo-2.t17596.html
Add-on này có tính phí, nên không hỗ trợ được
Sorry but this is a paid addon.
android88
is freeSorry but this is a paid addon.
It link other forum, and there, it is a paidis free![]()
android88
ok thanksIt link other forum, and there, it is a paid
android88
https://xenforo.com/community/resources/paid-threads.5760/
who could give me the details of this page?
thanks because i have the add-ons my i would like the description!
thank you for sharing @PVS @THB
